-   Suspension TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=421)
-   -   Opinions requested-on lower contol arms -lubed? (https://forums.maxperformanceinc.com/forums/showthread.php?t=444639)
ks gto (Cap) 06-09-2005 04:01 PM
I would like to have opinions on whether or not to grease the bolts that hold the lower control arms. I thought if they were coated with a light film of lithium that they would be less apt to "freeze up" -- or would that be bad because of attracting dirt etc? thanks, Cap
GTOFARM 06-09-2005 04:40 PM
lube the bolts, you will have no problems, look at it like this i have control arms with grease fittings
ks gto (Cap) 06-09-2005 04:45 PM
grease fittings ---good idea! Thanks, Cap
Shadowjack 06-09-2005 05:02 PM
If you have stock rubber bushings, there is no way to use grease fittings. When you tighten them down, the inner sleeve is essentially locked to the bracket. If you want to keep the bolts from rusting in there, coat them with grease, antiseize, or whatever.
