-   -   Pilot Bushing (https://forums.maxperformanceinc.com/forums/showthread.php?t=454280)
pggto 09-21-2005 08:58 AM
Pilot Bushing
Whats the easiest way to remove an old pilot bushing from the crank end? Thanks
BILTIT 09-21-2005 09:10 AM
Fill the hole with thick axle grease and then shove a shaft (same diameter as the trans. shaft) into the hole and the grease will push the bearing out.
Bill Hanlon 09-21-2005 09:14 AM
Pilot bushing removal
The trick I have heard of (but never tried myself) is:
1. Find a dowel (or use the frontshaft of the transmission) that is a slip fit into the pilot bushing.
2. Fill the bushing center with thick grease.
3. Align the dowel with the hole in the bushing and give it a sharp rap with a hammer driving the grease down into the hole.
The grease is supposed to pop the bushing out.
Be sure to wear eye protection.
fdowdy 09-21-2005 12:06 PM
I've tried the grease pack-'n-pound trick. Works great.
JoePapa 09-21-2005 05:13 PM
a slide hammer works well too...
GTOYANKEE1970 09-21-2005 09:59 PM
I've always used the slide hammer.
John
Formulabruce 09-21-2005 11:06 PM
"GREASE" is the Word......is the word......is the word....... yep, works well :)
janderson 09-22-2005 07:02 AM
Grease works well as mentioned, just try and get all the air out when packing the grease or when you strike the dowel or punch (or whatever you are using) the hammer will bounce back. Another method is to tap it and run in a bolt with an impact.
