-   Pontiac - Race (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=419)
-   -   Disk Brake Question (https://forums.maxperformanceinc.com/forums/showthread.php?t=464253)
69redbird 01-11-2006 11:50 PM
Disk Brake Question
Hey,
I have a question about disk brakes, I have drum brakes all the way around my 68 bird, and i want to run disc brakes all the way around. My question is can I use disk brakes without using the brake booster? I dont have one now just a master cylinder. I dont want the extra weight up front. Thanks
screamingchief 01-12-2006 02:30 AM
Sure you can use manual disc brakes,just be sure to use a propely sized master cylinder for your brake setup.
Also need to use the manual brake location on the pedal lever,still no biggie though...
My '72 firebird is a factory manual disc/drum brake car,so even GM did that on occasion.
rfb92345 01-12-2006 03:06 AM
We run manual 4 wheel brakes on my son's '69 f'bird.
69redbird 01-12-2006 12:18 PM
Thanks,
Were can I look for the correct master cylinder? Is there a website?
rfb92345 01-12-2006 01:32 PM
I will check with him and see just exactly waht master he is running.
Rob B 01-12-2006 02:54 PM
I switched from manual front drum to manual disks on my car years ago (OEM setup, not aftermarket stuff) and used the same master cylinder and proportioning valve from the drum brakes. Had no problems or anything goofy happen just as long as you have a dual master cylinder. I've done it this way and many people I know have done the same on all different years X and F bodies. Switched out spindles, brake set-up, and brake hoses and away we went.
69redbird 01-12-2006 02:59 PM
Rob,
Do you have to switch out the spindles, and does a dual master cylinder have both front and rear compartments? How would i know if i do have a dual? Thanks Again
RAIV55 01-12-2006 04:12 PM
I was thinking that drum brakes utilized residual check valves in the master cylinders and these had to be removed when switching to disc brakes.
Rob B 01-12-2006 04:16 PM
Originally Posted by 69redbird
Rob,
You'll have to switch spindles, you might have fun trying to find original OEM spindles. Yes on the master cylinder, yours is a dual, just take the lid off and you'll see 2 reservoirs.
69redbird 01-12-2006 05:15 PM
Rob,
Most kits I see include the spindles, so I guess those will work? Just have to tell them my year and make of car? Thanks
