Pictures of your 61-63 Lemans/Tempest
I love to see these car/wagons, can you post your pictures of them?
2 Attachment(s)
Here are pix of my Race car and my LeMans Convertible.
my wagon
3 Attachment(s)
Heres mine, 1962 conv. I have had this car for 15 years now and drive it almost daily. I live about 30 miles south east of Tom S. and I have had the good luck to have seen most of Toms toys.
Here's my work in progress...
Tim, looks great!
Pat |
My two 4-4-4's
4 Attachment(s)
'63 Le Mans 326 Auto - Currently in the chassis shop getting a mild makeover. ;)
3 Attachment(s)
My '63 that I can't seem to get my arms around - was supposed to be ready for Norwalk, NOT.
Shooting for Sept. 10th at the Grove. |
2 Attachment(s)
Where are all the 61-62?
wolf's 63
63 lemans 455 pic from norwalk
2 Attachment(s)
This is the only one I have pictures of... go figure.
2 Attachment(s)
Heres a pic of my 61 with 62 rear trim LOL.
Apache Warrior, do you have mounts under the block also? Or are the ones in the front it? |
Also have a really nice fabbed trans crossmember for my Jerico DR4! |
R70Judge, I have three engines for the car. With the 474 its run as fast as 9:72 @ 138.00 on motor.I currently have a 462 in it that was built for N2o and its run 10:13 @ 134.00 on motor. ( what a pig ) I didnt shoot it yet. Im also in the process of building an IA-2 that will go in next season. Im currntly deciding on which way to go with this motor as far as combination. Ill need to buy better cylinder heads for it also as my Edelbrocks wont fit the bill. This car is a complete street legal car not a stripped out shell type race car.
Apache Warrior, Id like to share some info on your engine install. Youd be better off mounting the front of the engine with a full one piece motor plate accross the front of the engine either behind the timing cover or water pump. And the use of a mid plate between the engine and trans. Your looking for trouble mounting to the cylinder heads. You dont want to be putting undo stress on the head bolts. Your head gaskets will fail. Dont use solid motor mounts or it will crack and fail the #2 main. Please veiw this as constructive criticism Im trying to help. Scott. |
Thanks - I do not have solid mounts and the cylinder heads are studded. The individual engine plates should be fine - the gentelman who fabbed them has them on many other customers cars with success. |
Ok, Than Ill wish you luck with your project.
| All times are GMT -4. The time now is 07:06 PM. |
