-   -   Whats it worth? 1971 Trans Am (https://forums.maxperformanceinc.com/forums/showthread.php?t=509495)
TransAmRIP 02-11-2007 02:37 PM
I have an opportunity to purchase a 71 Trans Am 455 ho (ye code) 4 spd. white with black interior 67,000 orig miles??. Good 20 footer minimal rust issues, good paint, honey combs, good interior. Would not need to be restored. Good daily driveror restore later. What would be a good ball park for this car in this condition.
Also, is that (YE) code correct for that transmission???
Any help here would be nice.
Thanks, Bub :noidea:
68bird400HO 02-11-2007 02:46 PM
YE code is an automatic transmission block, so, either the car was originally an auto or it is not numbers matching. Check the vin on the block and tranny to see which is the case.
TransAmRIP 02-11-2007 02:52 PM
71 TA
Ok Thanks
niceta 02-11-2007 02:55 PM
71 TA value
According to NADA website low retail is $17220 and average retail is $35245 and high retail is $58660. This is without air. Tag on around 1200, 2500 and 4200 respectively for air. This is the NADA value and may not represent what someone is willing to pay for this car. I am sure at BJ auctions the price would be much higher. Hope this helps.
FROM NADA WEBSITE
Low Retail Value
This vehicle would be in mechanically functional condition, needing only minor reconditioning. The exterior paint, trim, and interior would show normal wear, needing only minor reconditioning. May also be a deteriorated restoration or a very poor amateur restoration. Most usable "as-is".
Some of the vehicles in this publication could be considered "Daily Drivers" and are not valued as a classic vehicle. When determining a value for a daily driver, it is recommended that the subscriber use the low retail value.
Note: This value does not represent a "parts car".
Average Retail Value
This vehicle would be in good condition overall. It could be an older restoration or a well-maintained original vehicle. Completely operable. The exterior paint, trim, and mechanics are presentable and serviceable inside and out. A "20-footer".
High Retail Value
This vehicle would be in excellent condition overall. It could be a completely restored or an extremely well maintained original vehicle showing very minimal wear. The exterior paint, trim, and mechanics are not in need of reconditioning. The interior would be in excellent condition. Note: This value does not represent a "100 Point" or "# 1" vehicle *.
* "100 Point" or "# 1" vehicle is not driven. It would generally be in a museum or transported in an enclosed trailer to concourse judging and car shows. This type of car would be stored in a climate-regulated facility.
TransAmRIP 02-11-2007 02:57 PM
71 TA
Low Retail Value
FROM NADA WEBSITE
High Retail Value
If that is correct that the YE block is not correct for that transmission how does this effect the value???
niceta 02-11-2007 03:11 PM
71 TA value
68 bird is correct. You would have to see if the Trani has been changed or the motor. Either way in my opinion it would only hurt the value $5-7K as it is still a rare car. I would make sure that if the trani was swapped from auto to 4 spd you should make sure it was done properly. You need ask the owner if he has the build sheet. It will tell you if it was a auto or 4 spd. Hope this helps
71Formula 02-11-2007 03:49 PM
Mind if I ask how much they are asking for the car?
TransAmRIP 02-11-2007 04:02 PM
71 TA
$18000.00
68bird400HO 02-11-2007 04:46 PM
If motor is original and the tranny is not, I don't think it will have as much of an impact as if it is the other way around. From what I have heard non#s motors will have a 15-20% hit on the value of a done car. So if it would normally sell for $50k done, probably expect $40ish for non#s.
In checking the motor numbers, also make sure it has the correct carb, distributor, and shaker setup. These are very expensive items to find if missing.
What the car is worth is highly dependent on how correct and complete it is with all of its hard to get components.
kai 02-11-2007 04:54 PM
The 72(same value as 71) in the following link got almost 18K too.
http://cgi.ebay.com/ebaymotors/ws/eB...6681488&rd=1,1
If it looks better than that probably a good deal.
TransAmRIP 02-11-2007 06:37 PM
Not the car I am looking at but....
www.houston.craigslist.org/car/276063605.html
This is not the car but, he has the YE engine with a 4 spd to!
Look at the price . wow
niceta 02-11-2007 06:50 PM
Well I guess it's worth whatever someone is willing to pay after seeing some of the e-bay cars. I can't beleive what some people pay for things on Ebay!
eaglesan13 02-11-2007 07:40 PM
Last week a friend of mine in the San Jose CA area forwarded me a craigslist link on this very same car. There was no price and no reference to the location but the pictures were the same as this ad. So I emailed the guy and he sent a return email stating the car was in southern California and the price was $8000. What a diference a week makes!
kai 02-11-2007 07:44 PM
I know that they're called price 'guides' but they're all over the map. I'm confused over the pricing. The NADA site has an option to check off engines and lists all available in each trim (base, esprit, formula, trans am), including the 455/335hp HO for 71. Then when it comes up with a value for the car it adds 20% value to the car because of the motor. But there was only one engine choice for the 71 TA, so is the added 20% value erroneous and only meant to add value to say a forumula for that year.
The Nada site also list the value of a 73SD at 46K in excellent condition.
There is a 71 TA in hemmings right now for 79K.
niceta 02-12-2007 12:31 AM
OK, I see your point and do not profess to be an expert on 71 TA's although I have been following the prices lately. Was there not the option for the ram air III or Ram air IV in 1971? I don't know myself but I thought there was. I like to look at NADA and other "guides" if I am looking at buying because to me this is a more realistic, not so inflated value. If I were selling however, sure the Barrett Jackson and other auctions and Hemmings is a place to look to see how much people with too much money are willing to spend on a upper end car for a luxury investment. To me if I were buying a 73 SD $49K (NADA top cond) sounds maybe a little low but $125-150K sounds a little retarded. Yea, I know all the mopar stuff is bringing in that much and why shouldn't the pontiacs. Well in my humble opinion I think the mopar prices have been retarded for some time now. And if your selling a rare car and someone is willing to pay an exorbitant amount of cash hey thats great, I guess I will just bow out like I am going to do with this thread. Sorry Transamrip, Hopefully this does not cloud the issue with your deal.
Scott455HO 02-12-2007 07:21 AM
Definitely no ram air III or IV in 71, 70 was the last year for those motors.
bossbirdta 02-12-2007 08:42 AM
eaglesan13: the car your friend sent you the ad for from CL,is it the same one showing the car sitting outside in a storage yard??? i think it was listed as a TRAMS AM, and not TRANS AM.......
eaglesan13 02-12-2007 01:33 PM
It's the same car, I recognize the decal on the shaker door.
TransAmRIP 02-13-2007 09:03 PM
71 TA
Found out more about the car. It is the orignal motor with auto than :rain: was converted to 4 spd. Has the correct carb dist and shaker. Waiting on more pics to look further.
Zyman 02-13-2007 09:11 PM
71 TA. If the car is as described, I would be interested in it at $18,000 and would pay you a finder's fee.
