-   -   Engine serial number on 89 Trans Am GTA (https://forums.maxperformanceinc.com/forums/showthread.php?t=533594)
jackman 09-07-2007 11:43 AM
Does anyone know where on the engine I can find the factory numbers. I recently aquired a 1989 Trans Am GTA with a 350ci and am trying to determine if the engine is original. I was told the last four numbers should match the last four of the VIN.
WDCreech 09-08-2007 12:31 AM
This belongs in Pontiacs with non Pontiac engines. And who cares?
Dens71TA 09-08-2007 01:36 AM
Its on a machined pad at the head/block seam on the passenger side behind the A/C compressor.
jackman 09-09-2007 08:33 AM
Thanks, Do you know anything else about engine numbers? All I see there is either a #7 or a poorly stamped Z, I think it's the Z. Or do you know where I can look this code up?
