-   61-66 Big Pontiac TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=428)
-   -   motormounts (https://forums.maxperformanceinc.com/forums/showthread.php?t=551294)
lonli1 02-18-2008 07:30 PM
motormounts
thinking about replacing my 389/slim jim with a 350 th350 combo
my car 63 catalina
donor mid 70's le mans will i need to fabricate motor mounts positions also what other goodies could i use from the donor car? disk brakes? AC, rear end drive shaft...
lonli1 02-22-2008 07:32 PM
hello anyone help?
Stuart 02-22-2008 11:03 PM
What year is the 350 engine? If it's 1976 or earlier the engine mounts in your car should match right up. If it's newer than that, check the sides of the block to see how many bolt holes are there....if there's five holes it will work, if it only has three holes it won't match up to the '63 motor mounts without an adapter plate.
You'll have to do some modification to the transmission mount to make it fit, and probably relocate the crossmember a little. I don't know about the driveshaft, I suspect it won't work.
The rear end from the Lemans won't work, and the one in the '63 is a better piece anyway. The disk brakes won't work either. If the air conditioner is an aftermarket underdash unit, it can be moved to the older car. If it's an indash unit, I suppose anything can be made to fit anything with enough work but it wouldn't be worth the effort.
PITTSBURGH 64 02-23-2008 09:25 AM
My 73 455 bolted right in to my 64. I used the 64 389 mounts. I maybe mistaken but I thought my 455 had three bolt holes.
For discs I get the Scarebird brackets and use your stock spindles.
http://www.scarebird.com/12802/13701...ession*id*val*
Your 63 allready has the best rear end made.......................
