2002 TA power seats
I haave some 2002 TA power seats (both power tracks and lumbar) I am trying to put into a 68 FB....does anyone have a wiring diagram that shows how to hook up power to the seats? Or maybe you just know of the top of your head how to do it?
I have the schematics I just dont know how to move them around on a computer. So Ill try to explain. Do you have all the connectors to go with the seat track from the switch to the track motors? Power is supplied to the seat track switch at terminal F (orange wire) and ground is terminal C will be ground (black wire).
For the lumbar: supply power to terminal A on the Seat Cushion Air Control Module connector. Ground is supplied to terminal D of the module. Supply power to the F terminal of the lumbar switches. Hope this helps. |
Thanks for the help....all the wires and connectors are all hooked up for the seat motors and lumbar stuff. You lost me on supplying power to the lumbar connectors. Beccause I dont have a way to tell what the different terminals are. I can really on go by wire color. I'll take a pic of the bottom of my seats and the connectors so that maybe that will help you tell me what to do. I'll post it here.
Thanks for helping me out. |
This is the body side of the under seat conn. Hope this helps
Connector Part Information • 1206-4752 • 6-Way F Metri-pack 280 Series (BLK) Connector Part Information • 1206-4754 • 6-Way M Metri-pack 280 Series (BLK) Pin Wire Color Circuit No. Function Pin Wire Color Circuit No. Function A GRY 764 Driver Seat Deflate Relay Control A GRY 903 Driver Seat Deflate Relay Control B WHT 766 Driver Seat Inflate Relay Control B PNK 904 Driver Seat Inflate Relay Control C ORN 1240 Battery Positive Voltage C ORN 1240 Battery Positive Voltage D BLK 1450 Ground D BLK 950 Ground E BRN 763 Driver Seat Pneumatic Lumbar Solenoid Control E PPL 905 Driver Seat Pneumatic Lumbar Solenoid Control F PPL 765 Driver Seat Pneumatic Lateral Solenoid Control F RED 906 Driver Seat Pneumatic Lateral Solenoid Con |
judgethis-
I took a closer look at my connectors and saw where they are labeled with the letters....thanks for pointing this out.....I just hadnt looked close enough yet so now I will be able to follow your directions. Larry P- Thanks for the info....it helps out alot. |
| All times are GMT -4. The time now is 03:05 AM. |
