-   -   Digital TV/ Pontiac Gregg (https://forums.maxperformanceinc.com/forums/showthread.php?t=584396)
OINK 1 12-31-2008 10:26 AM
Digital TV/ Pontiac Gregg /HELP 1/2" stud ! where r u
Do I need to get a special antenna?
I want to keep the 20" CRT tv in the back of my 1968 Bonneville Station Wagon.
I have installed the correct 80 amp alternator and invertor, so we're all good in that department.
(I have it straped in a FAT childs safety seat.)
Will the Wabbit ears antenna I have on the car work, or do I need to go to a 12' full size antenna?
Does anyone know the drag coefficients of standard Rabbit ear antennas versus 12 ft. long multi-element antenna? How much should I adjust my dial in ? Will cross winds affect it?
I race up @ Douglas, Wyoming, it gets really really windy, is there a danger of the Station Wagon rolling over ?
Pontiac Gregg
Carl A 12-31-2008 10:41 AM
I say go cable better picture!!!
gto-owner 12-31-2008 10:45 AM
Look in the Lobby, under the post "Rave" lots of good info there
TransAmboy455 12-31-2008 10:53 AM
GO HD
OINK 1 12-31-2008 10:56 AM
Carl A /Pontiac Gregg
Carl, I HAVE tried the cable, but as it reels out the back of the car, the car gets lighter and I almost always break out !! So I switched to the antenna. Carl, you need to help me with ALL the questions !! Also, with the cable, I'd have to pay the disconnect/ reconnect fees everytime I go to a different track. Having the cable reel teched at check in time was a new and difficult problem for them, some times it take up to 5 mins. to tech it !!
Pontiac Gregg
fasteddy 12-31-2008 11:09 AM
I use the 12 footer on my GP. I put it as far back as I could. The wind is not an issue because the I have half inch cables securing it. It does make for some dandy wheel stands. Oh-I put the HD converter in the trunk next to the power inverter and battery.
Carl A 12-31-2008 11:30 AM
The new Fiber Optic Cable is the only way to go so small you can really carry a big spool
no need to rewind, now I'm just talking me now no need to rewind,I'm picking a direction and going for it and not stopping- exept for red lights;)
fasteddy 12-31-2008 12:04 PM
I have attached a good example of placement for best weight distribution and reception.
Carl A 12-31-2008 12:18 PM
Well hold on now thats the ticket ---A TRUCK-- I will have to rethink my thunking.
MandevilleBird 12-31-2008 02:00 PM
You guys are old school. Ya gotta go with the dish. It'll work from inside the car so, no wind resistance....and you get lke 200+ channels!
mash 01-01-2009 06:38 PM
the dish is an advantage on the roof when you have tail winds:D
GR8ONE68 01-01-2009 09:23 PM
You might be a redneck if:
You have a UHF-VHF-FM antenna mounted on the back of your truck!
BVR421 01-02-2009 01:39 AM
One day into the new year and you guys are already skeerin me
johnta1 01-02-2009 11:32 AM
Most of those won't work with your tv without a digital converter box. :(
You need the stealth antenna:
http://forums.maxperformanceinc.com/...pictureid=1553
If you add the 30" wheels, you'll have directional capabilities, also. :D
OINK 1 01-02-2009 12:19 PM
TV antenna help/ Pontiac Gregg
I just want to say thanks ! Great laughs, what a way to start the new year !!
Laughter, the best medicine.
We need more posts like this !!
Pontiac Gregg
