76 lemans brakes on 68?
Looking at buying a 76 lemans for parts 400 motor and trans, will the diff and front brakes interchange with a 68. Bear in mind parts that you can get from an auto wrecker in the us you cant get at all in Australia. this might be a good option for me.:confused:
Here's a good source of information for your differential question, although it is not exhaustive it may help. http://www.oldsmobility.com/10bolt-tech.htm
As for brakes, I am not at home and can't look things up in my books, but here's an article that provides additional brake swap information to get you going down under. :D http://www.goatsgarage.com/d2dlft.html |
No they won't. The 68's rear steer and the 76 is front.
Ball joints are different also. Mike |
Alright thanks guys, will pass on car and spend that money on purchasing correct parts, thanks for the information
| All times are GMT -4. The time now is 09:33 AM. |
