-   78 and Newer G-body Pontiac TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=443)
-   -   Help Rebuilding G Body Steering Column? (https://forums.maxperformanceinc.com/forums/showthread.php?t=584685)
DiamondJim 01-03-2009 01:00 PM
Does anyone sell a kit or bearings to do this? Does anyone have a link that shows an exploded view? My turn signal lever came totally out and while I have it apart I would like to rebuild it. Thanks for any/all help! -Jim
bigchief 01-03-2009 08:31 PM
about your question
i just had my buddy build mine into a tilt col. he has a body shop manager for gm.hit me back if still need help/
thanks bigchief.
ponchbro 01-04-2009 12:57 PM
Jim,
If your column is the one with the dimmer switch in it the lever is just a snap in type. I have a 78 Pontiac service manual I can try to take a picture and email it to you if you like!
DiamondJim 01-06-2009 10:43 PM
Thanks guys, I plan to work on it next weekend, I will get back with you if I get stuck. -Jim
DiamondJim 01-17-2009 08:50 PM
Just an update. I never could find any internal parts for the upper, I had several broken internal plasic parts, missing spring, as well as a broken die cast pivot deal that the signal lever snaps into. I also discovered that 78 is a slightly different colume than the 79 and up. The 78 has a different spline/groove arrangement where the lower shaft attaches to the upper(near the firewall). I was able to find an entire used 78 colume from an El Camino, it fits perfectly and all is well. Thanks -Jim
