-   74-76 Firebird & TA TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=440)
-   -   74 underside photo wanted (https://forums.maxperformanceinc.com/forums/showthread.php?t=601643)
takid455 06-13-2009 01:03 AM
looking for a photo of the underside of a 74. interested in the e brake mouthing. mainly the location when the cables end and hook into the u shaped retainer.
vidguy 08-19-2009 11:30 AM
Still need this? I just had to replace one of those if you are talking about the part where the cable comes out of the frame under the doors.. Mine was just flimsy enough that when I was putting my new brake lines in i bent it and broke it....Cut my hand!
I was mad and bent it back and forth until it broke off. (I had the e-brake cable loose and the clip off)
I was going to try to find one to weld back on but nobody was helpin. So I ended up making a part out of a L bracket I got at Home Depot. Worked out well. Made it with hand tools, drilled and tapped and bolted in. (no welder here)
I'll upload pics of the original side and my new part if needed.
takid455 08-20-2009 10:15 AM
I have a setup that has been working. thanks for the info.
