-   -   Shifter (https://forums.maxperformanceinc.com/forums/showthread.php?t=603174)
ksgto 06-27-2009 07:46 AM
Shifter
I have a 67 h/h shifter and in the restoration book it calls for two washers under the front mount. On mine it looks like it needs a bushing to keep it up for the cable not to be in a bind to be able to shift. Thanks for any info Bob
kate`s67gto 06-27-2009 08:39 AM
There are 4 thick(1/4")fiber washers 1 under each attaching point. But at the rear there is also 2 other washers(thin) along with the previous one mentioned.
ksgto 06-27-2009 09:21 AM
Thanks for the info Scott are these still available. Bob
kate`s67gto 06-27-2009 10:52 AM
No idea if the thick washers are still available. Here are the pt #'s thick is 544476 and thin is 9421394. These pt#'s are from the assembly manual. I did not have the thin washers in my car just the thick washers.
fyrffytr1 06-27-2009 02:26 PM
You must have read my mind! I was just about to post this same question. I only have two of the thick washers. Are the thin washers fiber or metal. Do they go under the mount or between the bolt and mount?
kate`s67gto 06-27-2009 02:40 PM
Fiber washers seat to floor then the thin washer with shifter sitting on the washers with the bolt securing . The thin washers only show at center tunnel top attaching points. I used a steel washer.
Old Goat 67 06-28-2009 07:13 AM
Could you please tell us the thickness of these washers?
Charles
kate`s67gto 06-28-2009 10:01 AM
Charles the thick washers are 6mm or 1/4 " thick. I have no idea on the other two washers that go at the back of the shifter on their thickness. i used two regular steel washers there. The washers are in the assembly manual a total of 6 washers are shown in drawing # 9778563 section 35D page 361. If my camera was not acting up i would furnish a picture of the washers. The Le Mans floor shifter does not have the thinner washers at rear of shifter . The Dual Gate or His/Hers shows only has these extra two washers.
kate`s67gto 06-29-2009 07:11 AM
3 Attachment(s)
Pics of assembly of His/Hers. Sorry about lousy pics.:o
Old Goat 67 06-29-2009 07:53 AM
Thanks for that page #. I see them there, now that I look in the book!
Shows 4 ea 1/4" washers, with two thin ones over the rear ones.
Charles
