-   -   help, vent window tab broke (https://forums.maxperformanceinc.com/forums/showthread.php?t=611892)
Pete Ripley 09-26-2009 09:20 PM
my vent window tab, the one at the bottom that holds the window in place in the frame and has a series of washers, a spring and a bolt. has broke off from the chrome that goes around the window. Is there any way of repairing this? It looks like pot metal so should I assume welding is out of the question? Any advice would be appreciated.
Frank R 09-27-2009 09:33 AM
You'll have to replace it. The same thing happened to a friend of mine with his 64 Corvette. It was the day before he was getting judged for NCRS Top Flight and I didn't have time to change it before you had to load up and go. I put expoxy on the two pieces and clamped it. It held long enough for him to get his top flight award. I changed the vent asm. a week later.
