-   Pontiac - Race (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=419)
-   -   Pontiac Racing Videos: (https://forums.maxperformanceinc.com/forums/showthread.php?t=614402)
PONTIAC DUDE 10-23-2009 10:33 AM
I think this should be a sticky and people can add their Pontiac track vids. From drag racing to road race.
Then post a little info about the car and engine combo. Time and place.
79TA455STROKED 10-23-2009 11:01 AM
Ill start it off,this is from the spring,first time out with new combo in sig.
Pump gas 93 oct combo.
full exh including tail pipes
3350lbs
10.18 at 134 mph
Car has come a long way since then,9's to come in coming weeks!
http://www.youtube.com/watch?v=2-cSj...layer_embedded
PONTIAC DUDE 10-23-2009 12:10 PM
Pontiacs in the Park. VMP 2008. Heads up Streetcar Shootout.
73 pills in a Big Shot plate. Stock suspension 3450 lbs.
Hydraulic Roller AND Pump gas. 9.30@144
Other lane is Joey Deyton out of Maryland. Fun times.
http://www.youtube.com/watch?v=BMFWOYr6VSE
bad69bird 10-23-2009 12:22 PM
Here's Jeff Kinsler and I at PITP 2008 Heads-Up Streetcar Shootout.
http://www.youtube.com/watch?v=Kuqv2...eature=related
ho428 10-23-2009 01:02 PM
NASA at Road Atlanta in June, lots of changes since, can't wait to make a new video.
http://www.youtube.com/user/428fireb.../4/fncE5BtOV0U
1968 Firebird, road race.
8 point cage w/ 2 x 3 welded connectors
Global West Cat 5 rear leafs
Billet A arm shafts w/ solid bushings front
Solid 1/2" lower body mounts
Kirkey RR seat, 5 point harness
22 gallon Jaz cell
365 cu in Pontiac
11:1 w/ KRE 290's w/ 2.07-1.66
Solid lifter cam w/ 1.65 rockers
SD Rods w/ clevite pistons
ARP Studded mains
Canton pan, melling pump
Front mounted oil cooler
Front mounted PS oil cooler
Remote oil Filter
MSD Pro Billet dist w/ 6AL
MCleod Auminum RR Flywheel, dual 8" iron discs
M-20 w/ Hurst comp plus
10 bolt posi 3.08
Vented rotors front w/ cooling ducts
Drum rear.
8" Rally II's rear
7" rally II's front
Goodyear vintage Blue Streak Bias tires
Mike S 10-23-2009 02:46 PM
This is from one of the 10.0 index races at Atco. There are 2 pontiacs that compete but I am the only one with a pontiac engine. I am 4th in points behind a 67chevelle, 92mustang and 84regal.
http://www.youtube.com/watch?v=-38ysafINfc
This one is a slow motion one from a qualifying pass
http://www.youtube.com/watch?v=9I8FqHTFl7c
66bonne 10-23-2009 09:36 PM
http://www.youtube.com/watch?v=g8gUEuDuQTQ
Not our fastest pass but it sure was fun !!
Jim
BLANK1 10-23-2009 10:09 PM
Here's my brother's '69 GTO on the Goodguys Autocross in Columbus, OH.
505 C.I., dynoed at 606 hp and 640 tq
310 cfm Edelbrock heads, 1.5 rockers
Comp hyd. roller 252/262 magnum lobes 110 LSA
Victor and 1050 Pro Systems Dominator
1 7/8 Dougs Headers w/3" exhaust and Super 44 mufflers
TH-400 w/Gear Vendors
3.73 geared 12 bolt
Air Ride suspension
18" wheels w/Nitto 555's
http://www.youtube.com/watch?v=cdHxRogsqsk
T Syron 10-23-2009 10:10 PM
Only video I have of my car, thanks to Bernie Cutrone. 11.03 Pass
Tom
http://s182.photobucket.com/albums/x...nt=goldgto.flv
marks73ta 10-23-2009 11:16 PM
This is my '73 T running a tunnel ram and 200 shot nitrous. This site has a lot about my TA and this page covers a write up of the run that night. This was prior to the turbo install. Mark L http://www.americantorque.com/page/1/63/
x
misaac 10-23-2009 11:46 PM
This is my wagon running at Gateway test n tune April and October of 2008. Pump gas 468 with un-ported #96 d-ports, UD 231/239 @.050, THM400 and 3.23 8.2. 4000 lbs with me in it. 180hp jetted plate on a RPM and Torker2. 28x9.5 14" ET drag.
http://www.youtube.com/watch?v=XGf_pe66mOE
http://www.youtube.com/watch?v=obtS3...eature=related
Old Man Taylor 10-23-2009 11:51 PM
This is the only video of my car that I am aware of that is still on the Internet. There are several races on it. It took place at Madras, OR on the Memorial Day weekend. It is an eighth mile track. My first run is in about 35 seconds.
http://www.esnips.com/doc/00f83653-d...s-Part-3-of-3#
wreckmastr 10-25-2009 10:56 AM
Not our best pass but here is one.
8.39 @164
http://www.youtube.com/watch?v=WYroQYnX3Us
lemans411 10-25-2009 11:12 AM
best pass so far with new combo. ran this oct 17th at cedar falls . 67 lemans 535 blow thru with an 83 mm turbo ran 10.53 at 126 with a 1.49 60 foot 4100lbs with me in the car. too bad i hurt the turbo that weekend . oh well i wanted to go bigger anyway.
http://www.youtube.com/watch?v=bvFnA6miNmk
Brian Baker 10-25-2009 11:16 AM
Interesting view for a video, from the door on my old Discomobile (thanks Fish!):
http://www.youtube.com/watch?v=R2D8qkM70Yk
JD 10-25-2009 11:31 AM
Here is a not so good video of the quickest pass on my car so far.
http://www.flickr.com/photos/35298103@N08/3464068535/
Cliff R 10-25-2009 12:17 PM
Here's our car running in the final round of the Tri-Power Nat's in the King of the Hill race:
http://www.youtube.com/watch?v=t9eWgLd0q-U
harry k 10-25-2009 01:02 PM
both of HK Motorsports Dyno Shop street cars @ 11sec passes :jumping:
http://s79.photobucket.com/albums/j1...agStrip068.flv
www.HKMotorsportsDynoShop.com
JohnJudge 10-25-2009 03:32 PM
Here is one of mine from this past Friday night....
http://www.youtube.com/watch?v=5ZVm5fw4xXw
gold bird 10-25-2009 11:25 PM
good times!
http://www.youtube.com/watch?v=MC-dganA2jQ
