Ram Air 3 manifold clearance
Yesterday, I mounted my RA3 manifolds on my 72 GTO.
The car has new 455 HO motor mounts and like it is now, there´s about half an inch of space between the control arm mounting bracket and the outlet flange on the drivers side. I am curious how much space you guys have between? Regards Johan , Sweden :snow: |
2 Attachment(s)
Here's some pictures of my 71 conv with 66/67 RA manifolds. The drivers side was very close to the lower control arm mount. I ended up using a bolt that took an allen head wrench to get them tight. Worked fine for many years.
3 Attachment(s)
I am planning to do some bracket racing this summer,
and was a bit worried that the flange/manifold would touch the bracket when the engine twists. Like for example when launching with slicks mounted. Here´s a couple of pictures. |
Ok, that sounds good.
Thanks for the answers. Regards. Johan |
| All times are GMT -4. The time now is 05:56 PM. |
