-   78 and Newer G-body Pontiac TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=443)
-   -   engine swap (https://forums.maxperformanceinc.com/forums/showthread.php?t=631607)
wilddawg01 04-24-2010 03:31 PM
engine swap
i have a 1982 grand prix that we swapped out the v6 for a 455 from a 1975 gp we used the brackets and motor mounts from the 75 gp the problem we have is the motor sit's about 2-3 inches to high does any one know what brackets and mounts to use to lower the motor any help would be great
mguerci 04-25-2010 10:53 AM
You should use the motor mounts for a 301 that came in the 82. They will line right up.
BOPcollector 07-13-2010 09:54 PM
1982 used a Buick V6,350 Olds diesel or a Chevy 305. But the engine mounts from a 301 equipped '78-81 would work.
Mr Twister 07-14-2010 06:14 PM
Where can you get them?
