-   -   what are these 2 parts I found in my 69GTO? (https://forums.maxperformanceinc.com/forums/showthread.php?t=635087)
magicv8 06-02-2010 05:03 PM
http://img.villagephotos.com/p/2008-...0/MVC-004F.JPG
the round one is rubber, the other is steel
robz 06-02-2010 05:09 PM
One on right is rear frame to bumper support...
webfoot 06-02-2010 05:13 PM
Left looks like a rear spring isolator, goes on the upper coil spring to body perch.
x2 with robz on the other.
magicv8 06-02-2010 05:13 PM
thanks - I need a lot of help
webfoot 06-02-2010 05:19 PM
I love "what is this" posts, and have posted many myself - keep 'em coming!
magicv8 06-02-2010 07:53 PM
uh oh..........
webfoot 06-02-2010 09:39 PM
codyyy 06-03-2010 12:16 AM
The metal piece almost looks like the piece that goes to the back of the frame next to the coil bucket / crossmember there, but I believe that is welded in.
Bet Winner 06-03-2010 09:40 PM
If you find a unique large thick square threaded nut, it bolts on the small end of the bracket against the frame. The nut will probably clean right up. I wonder if mine is stainless steel because it looks like new when cleaned--unlike the other bolts/nuts which may need to be replated.
And those spring isolators have been reproduced, unlike the square nut.
magicv8 06-04-2010 10:54 AM
I'll look in the bag of hardware marked "unknown" because it's not in the rear bumper bag.
thanks - Dave
