-   -   Horn won't shut off (https://forums.maxperformanceinc.com/forums/showthread.php?t=636982)
motor29 06-23-2010 08:15 PM
Horn won't shut off
I finally connected my new horn relay , when I connect the hot lead the horns sound and won't shut off. I checked the steering wheel horn contacts and nothing is touching. Where should I check ?
Herb Hagan 06-23-2010 10:23 PM
Check the horn relay on the firewall inside the engine compartment
2002Z4CSS 06-24-2010 07:10 AM
Make sure the circuit from the horn relay to the steering column is not grounded. :)
mike nixon 06-24-2010 12:50 PM
wiring in the column if it's tilt for sure.
May still be that if it's not.
motor29 06-24-2010 01:19 PM
I checked the horn contacts so it's not that, all the wiring forward of the firewall is new. I guess I will be pulling the steering wheel next.
2002Z4CSS 06-24-2010 03:01 PM
Unplug the turnsignal switch first and see if the concern goes away. :) If it does, the short is in the column, if not then the wiring to the relay or the relay. :)
motor29 06-25-2010 06:39 PM
Well I decided since I had the steering wheel pulled off I replaced the turn signal switch. I opened up the relay and the inside was shorted out , the wires were burnt. I guess I will be getting a new horn relay. Thanks for the responses.
