Kickpanel Speakers with Vintage Air
Has anyone tried using the kickpanel speakers from Custom Autosound with the Vintage Sure Fit Air Conditioning System? I was just wondering if the A/C kickpanels speakers will fit with this system or are there issues with the compatability?
Thanks, Dale |
Reviving this one - anyone?
I ended up using the one for A/C on the driver's side and just blocked off the outside vent with a piece of metal. I used the one for a vent on the passenger's side because the hoses pass through where the vent would go. I had to do some minor trimming, but it worked out well. That means you have double the expense because you need to buy both the A/C setup and the one for the vent setup. If you don't mind having the vent louvers on the driver's side, you could probably leave the driver side vent in place and working or just block it off and use the kick panel with the vent and it just not be operational, you can get away with just buying the kick panels for the vent setup. If I remember right the with A/C kick panel would not fit on the passenger side because it hit the Vintage Air system. Let me know if you want some pictures and I will take some and attach them. You will also have to bend the parking brake to get it to miss the speaker. Also, not a big problem, just be careful. The speakers you use have to be a shallow depth speaker or they won't work in the kick panel. I originally had bought Alpine speakers and they were too deep.
This is the guy I bought them from. https://garytayman.com/kickpanel.htm Let me know if you need any additional information. Take care, Dale |
Great info - thanks for posting. Just noticed yours is a 69 while my LeMans with VA is a 64- not sure how different they are. I also have VA in my 69 bird and was able to add speakers in the kick panels 4x6 Kenwood and shallow.
Gotcha - thanks!
Dale |
2 Attachment(s)
Cool- if you don’t mind posting pics that would be great for me and others looking to do this mod. Here are a couple of pics of my kick panels.
Of note, I bought the car from a friend and haven’t looked at the sheet metal behind the kick panels. For clarity, did you buy the panels with the hole for the speakers or made your own? |
3 Attachment(s)
Here are a couple of pictures. You can see on the passenger side where the hoses of the Vintage Air goes through the old vent area. Let me know if you need more detailed pictures.
Dale |
Thanks for posting - is there a recessed area in the sheet metal behind the kick panel? Looking at the kick panels in link you posted I would go with the AC panels and the passenger side panel seems it wouldn't be too difficult to install. Of course I'd have to paint them tan. I am concerned on the fit on drivers side and what is involved in bending the parking brake pedal arm.
https://garytayman.com/abante/index....product_id=157 |
Dale |
Do you have any pictures that depict how much you bent the parking brake arm?
Dale |
2 Attachment(s)
3 Attachment(s)
Dale |
Thank you! What is the rest of your sound system and how does it sound?
3 Attachment(s)
Dale |
Thank you - I like what you’ve done there. I’m considering the kick panels with the kicker speakers and a 4 channel BT amplifier so I can keep the factory radio intact. I’m also looking Kicker 6x9s for under the rear deck - one in the already cut out speaker hole and the other in the area where defogger is. The kick panels I’d have to paint to match the interior.
Regarding the tweaking of the parking brake is the forced bend at the bracket where it mounts to the firewall? Meaning, did you pull on the whole assembly? https://www.crutchfield.com/p_113M50...C-M5024BT.html |
Dale |
I thought about upgrading the factory radio. I bought the car from a friend and he put in a factory correct speaker in the dash which matches the radio output. Of course the radio is AM only but it plays well - I’m really surprised it still works. Even though the car is far from original I can’t get myself to cut into it…
| All times are GMT -4. The time now is 04:59 AM. |
