-   70-72 GTO Tempest & LeMans TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=436)
-   -   steering wheel not straight (https://forums.maxperformanceinc.com/forums/showthread.php?t=659513)
raidex1 03-03-2011 10:01 AM
When parked and the front tires are straight my steering wheel needs to go to the right about 3 inches in order to be squared up. Can I drop the pitman arm turn the steering wheel straight and put pitman arm back on steering box? I changed steering box and that was the only thing that was apart.
PMDRACER 03-03-2011 12:45 PM
Not usually. IIRC, the pitman arm is keyed so you can only put it on one way.
The easy way to fix it is to loosen up the bolts (2 ea.) on the tie rod sleeves and turn both of them equal amounts in the same direction. Go about 1/2 turn at a time. That will re-center the wheel.
Edit:
Nice car, BTW!!!
85_SS 03-03-2011 06:43 PM
Can the steering wheel itself be rotated on A-bodies or does the horn mechanism only allow a single position? If so, perhaps it's off by a couple splines?
Mine is off a touch as well - I was hoping to be able to address it in this manner when I change the ignition cylinder in the spring...
GStage1 03-03-2011 09:54 PM
Sometimes the alignment will take out the mis-alignment with the steering wheel....otherwise you can remove one of the teeth on the lock plate and re-orient it on the steering shaft.
UPC-WU2 03-03-2011 10:16 PM
I agree with PMDRACER. I did this on my GT-37. It takes a little time but it is not difficult.
West Coast GTO 03-04-2011 01:17 AM
The adjusters for the tie rods sleeves are the answer but recommend that, after the adjustment, you still have the front end aligned. If not aligned better than by eyesight, can scrub tread off front tires.
My two cents.
Rob B 03-04-2011 08:16 AM
Do what PMD And West Coast said but make sure you do it with the car on the ground. not on jackstands and either turn both adjusting sleeves at the same time or have someone help you. This is how most alignment shops set the steering wheel. The steering wheel can only go on one way because of the horn button.
It only takes a few minutes to do this, no big deal.
85_SS 04-17-2011 09:12 PM
Just to add to this thread - I recently swapped a new steering wheel in my GTO and you are indeed able to rotate the wheel on the shaft several splines to make up for minor differences. The lockplate and dust cover both have a slot in them for the horn contact that allows for this rotation/adjustment.
Here's a couple pictures that show the notches that allow this rotation:
http://www.buickperformance.com/wobble4.jpg
http://www.buickperformance.com/wobble1.jpg
Picture source: http://www.buickperformance.com/tilt...lumnwobble.htm
...three inches might be pushing it, but if you have a steering wheel puller, it would be a ten minute job to give it a try. You don't even have to pull the lock plate as the plastic horn contact/cam cancel ring will rotate underneath it.
Lemans1970 04-18-2011 11:20 AM
I would definitely take it to an alignment shop before pulling/adjusting at the steering wheel, pitman arm, steering box, or anything like that.
Terry Gartner 04-18-2011 05:22 PM
Something else to consider. This is something I've done. The lower steering shaft where it mounts to the rag joint should only go one way. The two bolts that fasten the two together are different sizes so you can only attach them one way. When people remove the column they have a tendancy to disgard them and put what ever works in there. I may be all wet, but just something I've noticed.
