-   Big Pontiacs(including G-body) FOR SALE (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=458)
-   -   1963 Catalina (https://forums.maxperformanceinc.com/forums/showthread.php?t=674965)
punisher7 08-26-2011 01:15 PM
1963 Catalina
2 Attachment(s)
I am selling my 1963 Pontiac Catalina 4d hardtop 389 2bbl factory power brakes, power steering and AC. AC compressor was removed from the car, but is not seized. It will be included with the car. The car runs and drives like it should, and is good on the city streets and the highway.
I have put quite a bit of work into the car
New dual master cylinder (ditched the usicide single cylinder)
All steel brake lines replaces
New brake hoses
New wheel cylinders
New brake pads
Turned the drums
New voltage regulator
New NOS tail light lenses
New upper and lower radiator hoses
New 160 degree thermostat
New iginition (Accel super coil)
Accel wire set 8mm
Standard Electric blue streak Distributor cap
Standard Electric Blue Streak rotor
Standard Electric Blue Streak points/condener
Autolite 86 plugs
Kelly Charger Tires white letter (750 miles)
original rims with 1960 dog dishes
New fuel pump
New fuel filter
oil changed 200 miles ago
exhaust is also new
Has an oil leak. the oil pan gasket needs to be replaced. The transmission pan gasket should also be replaced. I have the transmission pan gasket already.
I am open to trades, I prefer a 40s-50s project car, but will consider cars as new as 74. I am open to cars in any shape. I would prefer your non running solid project in trade for my running daily driver.
Call, text or email whenever you like, I work odd hours. If you leave a message please leave a good time to get back to you.
Thanks,
Dan
414 915 4979
I am looking to get 4500 obo
punisher7 08-28-2011 01:35 AM
SOLD!
