1970 Trans Am RAIII in Hemmings
http://www.hemmings.com/classifieds/...m/1279462.html
Check out this one owner documented 70 TA with RA III, 4spd and A/C. |
And Performer intake!! Nice car still..
$45,000...........jeez
That Trans Am looks very nice.
Could you get a close ratio 4 speed and a/c?
I dont think so.
It seems that the only time I see M20 is in 3.55 rears every other rear seems to have an M21. I was also under the impression that the rear had to be 3.23 or less to get A/C. This to prevent the A/C compressor from crapping out. Not an expert at this. Just what I observe.
The standard rear axle on a/c cars was a 3.31, in fact, I'm pretty sure it was required. I know an M20 was available on a/c cars because I owned one. I just didn't know if you could get the close ratio trans on a/c cars.
Nevertheless, this is a cool car. How many cars this original, including window sticker, have any of us seen...? From my perspective, few enough that it makes putting a value on it a bit more difficult than with the normal fare... |
Reckon it would spin those polyglas tires? Very special car/history to be one owner. Neat piece.
I think...
[QUOTE=scorpio ps;4406377]It seems that the only time I see M20 is in 3.55 rears every other rear seems to have an M21. I was also under the impression that the rear had to be 3.23 or less to get A/C. This to prevent the A/C compressor from crapping out. Not an expert at this. Just what I observe.[/QUOTET I think you may have that backwards. The M-21 is the close ratio with the 2.20 first gear reqiring a lower-ratio [higher numerically] rear. The break used to be at 3.90 gears on A-Body cars...not that well-versed on the F_Bodies...but never have seen an air car with a close-ratio box. JMHO. Ron
I think...
[QUOTE=scorpio ps;4406377]It seems that the only time I see M20 is in 3.55 rears every other rear seems to have an M21. I was also under the impression that the rear had to be 3.23 or less to get A/C. This to prevent the A/C compressor from crapping out. Not an expert at this. Just what I observe.[/QUOTET I think you may have that backwards. The M-21 is the close ratio with the 2.20 first gear reqiring a lower-ratio [higher numerically] rear. The break used to be at 3.90 gears on A-Body cars...not that well-versed on the F-Bodies...but never have seen an air car with a close-ratio box. JMHO. Ron
