-   93-02 Engine Tech (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=539)
-   -   3.4/60 degree v-6 tech? (https://forums.maxperformanceinc.com/forums/showthread.php?t=688320)
694.1 01-27-2012 11:15 PM
Done alot of surfing & have seen almost nothing on waking up the 3.4 engine.
I have a 4th Gen bird on it's way & am looking to get busy.
Can anyone point me in a productive direction?
And I am not talking about fliping through a Summit catalog or adding a blower.
Cammer-6 01-28-2012 07:38 PM
have you signed up to any 60* GM websites?
alot of 3100 and 3400 stuff will work with some work but
if you really want to increase HP look at the 3900.
694.1 01-29-2012 02:26 PM
Thanks Cammer
My searches the other day did not lead me to many productive sites & I guess I'll search further.
3.9? I am unfamiliar, this late model stuff is all gnu to me.
Cammer-6 01-29-2012 08:09 PM
I just sold an 06 3900 to a friend whos replacing his 2.8 in a fiero.
he will more than double his HP stock and torque curve is almost flat from 1500-5000.
Bad part is no parts on the 3900 interchange as the bore spacing was increased slightly.
But its a real strong 60* motor and cheap enough to look at replacing your entire 3.4.
As for souping up the 3.4,it would be cheaper to look for a 95+ with a 3800.
http://forum.camarov6.com/index.php
www.fullthrottlev6.com
694.1 01-29-2012 10:53 PM
Cammer, those links are just what I was looking for!
You are the man.
HO 67 BIRD 01-29-2012 11:03 PM
http://60degreev6.com/forum/forum.php?
Also try this website.
Cammer-6 01-30-2012 09:10 PM
opps forgot that one
Im a member of all of these
pontiacjeff 02-01-2012 12:54 PM
the 3900 will require alot of work in a camaro. you will need a custom intake manifold b/c there is no upper plenum for rwd and the 3.4 intake will not work on the 3900. Aside from that, it is a great engine, with the Impala version having DOD technology (Displacement on Demand, cylinder deactivation) for great gas mileage. It was rated at 240hp in the vans and G6 GT, non-DOD.
I specialize in the GM FWD v-6's (and camaro). Contact me via email or PM if you want more info.
