-   Interior TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=497)
-   -   65-66 B body dash pad compatability (https://forums.maxperformanceinc.com/forums/showthread.php?t=691197)
FAT CAT 2+2 02-25-2012 10:43 AM
What models have the same dash as the 66 2+2 catalina?
Wondering if 65's will work.Are they the same?
chiefpontiac66 02-25-2012 11:28 AM
I'm not sure about non-a/c cars, but my 66 a/c dash pad was not the same as 65.
65WJ 02-25-2012 11:54 AM
the front lip is different. 65 is flat 66 is round. On the A/C cars the vent is in the middle for the 65 and on top for the 66. Other than that they are interchangeable.
patrick
stevep 02-25-2012 11:55 AM
You can make them work, but they are not the same.
66bonne 02-25-2012 12:52 PM
I agree with SteveP. They are interchangeable. Since the Catalina pad only covers half of the top of the dash you should have no problem with fitting a 65 to 66 or vice versa.
If you have an A/C car then you need to use the a/c plenum that goes with that particular year.
Jim
FAT CAT 2+2 02-26-2012 11:35 AM
Thanks guys!
So, there are no other models in 66 that are the same as the catalina/ventura/2+2.
65WJ 02-26-2012 12:10 PM
They are all the same for all models with the difference in appearance listed in previous posts.
When removing there is a screw the protrudes through the firewall by the wiper transmission. It can be a real pita if you do not know about this last nut.
patrick
FAT CAT 2+2 02-27-2012 12:24 AM
Thanks for the info.
