-   -   Power steering box help (https://forums.maxperformanceinc.com/forums/showthread.php?t=709916)
Aus Goat 09-28-2012 06:52 PM
Guys
Some bright spark put in the wrong hose connectors for my power steering box.
This could have been done when converted to RHD but anyway.
What is the right thread size for the SAGINAW steering box for a 1968 GTO.
I will be looking for the connectors / steel tube only ( steering box end only ) as i will need to wield into my lines at the steel tube lines due to the length of hose required for RHD
Craig
Attachment 298709
scott0 09-28-2012 09:17 PM
As long as it is a older steering box one fitting is a 5/8 the other is a 11/16. On my car I used steel adapters to change it to 6an hose. that way you can make your own hose whatever length you need. It worked out really well. My car is not rhd, but the concept is the same.
