68 400 timing cover swap
:usa2:Does anyone know if I can use a timing cover and water pump from a 72 350 on a 68 400 for better cooling or am I wasting my time?
I have all the acc. brackets and pulleys from both engines. Its going in a 68 Bird Thanks in advance for any help. |
As long as you get the right cast full vane impeller water pump and clearance the divider plate .
What I'm going to use is in the car now. Im putting in the 400 and wanted to upgrade the cooling system. Will the later setup be any better?
| All times are GMT -4. The time now is 08:07 PM. |
