| 'ol Pinion head |
03-25-2013 10:02 AM |
The housing is indeed an 8.5 X-body piece from a Seville, & originally had 5 on 5 bolt pattern axles. I have several Seville housings with pinions & the flat flange still in them...just core housings to build off of.
You will need the 3R pinion flange which was used on the majority of 8.5 rears. Should be easy to come up with pinion flange, even in Australia. If swapping from your early Birds 8.2 10 bolt rear, will need to shorten your original driveshaft 7/8" to 1".
