-   -   SPEEDOMETER CABLE ROUTING (https://forums.maxperformanceinc.com/forums/showthread.php?t=724095)
peter g 03-27-2013 11:34 PM
Does anyone know the correct routing for the speedo cable on a 68 gto with dearborn transmission passenger side drive gear? A picture would be great.:)
68gtoMN 03-28-2013 01:48 PM
Let me pull a picture from my carbonite account and post here for you - from an original, unmolested car found in a salvage yard here. Front of car is to the left of picture. Picture taken with car being held up by huge fork lift
http://i49.tinypic.com/5ttldx.jpg
Cable was routed under the trans toward driver's side, then through body clamps up to normal location. I hope that helps.
peter g 03-28-2013 06:26 PM
Thanks very much,i thought it had to go like that.All other sources said different and showed fitting on drivers side.:)
