455 use what i have
Hi Guys, i have a 73 455 that i am going to put in my 74 ta. im going to take out the original 74 455 and put on a pallet. i have found that the 73 has about .002-003 wear in the clyinders. it also has the 4x 1h heads, i was thinking about honing the clys and re ringing it, new bearings new t chain new oil pump and i have a ppr tc 01 hf cam. the heads i was going to cut .050 to 104 cc,s. would that get me to 8.7-8.8 comp.? the pistons seem to be at .005 deck. i dont have a big budget at this time so id like to get what i can get with what i have. also would it be worth it to work the ports a bit, like maybe the jim hand way in his book ? or not. thanks BLUE TA ps what hp and trq would you think?
You could hone for moly rings and re-ring with file fit rings, but you need to remove any ridge at the top of the bore.
Cutting the heads .050" is good to hit your target compreesion range, but I would also spend the bucks to mill the heads intake face Area .025" so you do not have a pain in the ass bolting down the intake manifold. If those heads have pressed in rocker studs you at least get them pinned, and keep your total valve lift to under .480" with the stock installed height valve springs, and thats another thing, the valve springs need to go as I can bet you and win everytime that they are far below the minium pressure needed of 110 lbs. Air flow is everything to a big cid motor like that and any porting you can do to those heads will help,the exh side of those 4X heads really need it! Just do the porting before you get the valve job done, that way if you slip with the grinder and nick a valve seat it will not be a issue. Also even though you are on a budget get a valve job done and any guides and or valves replaced that need it, also go for the 10 buck price tag of new valve keepers, Their is no worest feeling than killing a good running motor due to a failed stock 4 cent valve keeper! keep the peak rev`s with the stock rods to 5400, and any constant reving to 4500 and the motor should live long life! |
Thanks steve 25, i hadnt thought of the keepers, cheap ins. thanks for all your insight. BLUE TA
| All times are GMT -4. The time now is 10:15 PM. |
