-   67-69 Firebird TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=432)
-   -   Wiring schematics / diagrams 69 (https://forums.maxperformanceinc.com/forums/showthread.php?t=727996)
PMD1969 05-17-2013 04:22 PM
I have a copy of the wiring diagrams for a 69FB that cover the front and back in halves. Great diagrams. Mine seems to be missing some of the other electrical components (ie radio) for color designation.
Anyone have a diagram or at least a color designation for the other optional pieces for a 69FB?
It would be a great big help when I pull it apart to get everything working again.
Marc
Schoust 05-17-2013 06:08 PM
I would love an all inclusive detailed diagram with any and all possible options included. That would be great if one existed?? I'm having a problem with the trigger wire on the horn circuit and unfortunetly the basic diagrams do not show this either....
PMD1969 05-17-2013 08:21 PM
I have the same issue with my horn. Other things that don't work are the radio, blower fan, cig lighter, etc. They all used to work until "I" restored everything 20 years ago. They haven't worked since.
Schoust 05-17-2013 09:30 PM
Mine all worked before disassembly and reassemly now the trigger is no longer working? I can activate the horn when grounding the green wire so whatever the issue it is comming from under the dash.... I suspect that somthing was either crossed up or missed when reassembled. This is what happens over the course of 13 years....
Schoust 05-22-2013 05:12 PM
I just figured out what happened to my horn! I have a Wood Sport Wheel and there is a small pin with plastic Aroun it that appears to have broken? I am able to ground the screw driver a make the horn beep. I believe this pin to be my issue. Now anyone have any IDE where to get them?
Held for Ransom 05-22-2013 05:39 PM
PY.
http://www.pysales.com/images/Gmi129.jpg
Unless you need the canceling cam (didn't see PY carrying those for your application).
http://cgi.ebay.com/ebaymotors/ws/eB...m=130883328131
I'm not sure what year/usage this eBay link actually is selling.
