-   EFI Tech (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=570)
-   -   Which EFI System (https://forums.maxperformanceinc.com/forums/showthread.php?t=731369)
lmf01 07-02-2013 09:59 AM
Which EFI System
Hi All,
I am really looking into converting over to an EFI system and wondering if anyone has experience with any of them. Professional Products Powerinjection 3 seems a good choice but I have read some complaints about their after purchase customer support. The EZ-EFI or the MSD Atomic EFI are also possibilities. Currently a Holley Double Pump 750 with return pressure regulator.
Any help is always appreciated.
1967 Firebird
1971 455 bored 40
4 Speed Muncie
Hydro roller cam
MSD Ignition
lfdsteve 07-02-2013 10:54 AM
Run, don't walk away from powerjection 3. Reasons? Well first I should say i am in the early stages of setting mine up. First and foremost, if your looking for a plug and run system, this is NOT for you. Even their own techs ( x techs) say it is a complicated system to configure, not plug and play. Second. Software is glitchy, from what os it runs on, it's annoying tendancy to hide files and the numerous work arounds that you need to rember to get around these glitches. Third, almost every component shipped with the kit sucks. Plan on replacing the TPS and temp sensor right out of the box. Have a drill handy to rework the secondary linkage as it works poorly out of the box. Fuel on demand iffy, fuel filter And pump useless. If you choose this route at least buy the basic kit and supply your own. Finally, support at least online from the company is non existent. There are some very helpful people on the forum and I am getting my system in line but they do not work for the company.
I have not given up (as I am already invested) and admittedly have no experience with the other systems so am not sure if any of the above applies to them as we'll.
My 2 cents anyway.
Steve
TheSilverBuick 07-02-2013 02:28 PM
My 2 cents anyway.
Steve
Buick guys seem to have the same complaints about Powerjection 3. I have no hands on experience or real opinion on the other plug and play setups.
HWYSTR455 07-02-2013 02:37 PM
So you're considering a throttle body style setup? For the same money just about, you can get a port injection setup, may want to consider that. Once you get all the support items in place, like fuel system, sensors, ECU, you are not far from a port setup. Much more flexible for one. And you can go sequential if you'd like.
old66tiger 07-02-2013 07:55 PM
I have a FAST EZ port injection setup and it works well. No problems to date and throttle response is crisp. All adjustments are easy and with the exception of idle speed, all are made from the drivers seat. Plug and play but make sure you do your homework on a proper fuel system.
Formula8 07-02-2013 08:14 PM
There would be a FAST EZ on my car right now if my motor didn't eat a throttle plate bolt. That being said, this is a Pontiac site which means get ready for a flood of recommendations that a carb is better and FI is a waste of money. I say there is a lot more to enjoying a car than screwing around tweaking on a carb for weeks. If one has a lot of money tied up in a carb then use it. If one is starting from scratch and wants to invest in FI for nothing other than improved driveability, I am all for it.
Fishin2Deep4U 07-02-2013 09:32 PM
I also recommend a port system vs tbi. But the differences when running are pretty minor.
I would also only get into a system that also allows for ignition control.
There's lots of choices out there. I went with Megasquirt and it's clearly not plug and play. But if you start with a clear plan, it's pretty easy to get predictable results.
Dave
#1WideTrak 07-02-2013 10:08 PM
Dave
Why is that your preference? Excluding the actual EFI "ecm" and other air//fuel components, what other parts or mods are required for the distributor?
Fishin2Deep4U 07-02-2013 10:51 PM
Depending on the system, it can be as simple as a locked out dizzy or as complex as coil on plug. Most commonly, an hei is used. But I have seen points distributors used with an ignition box.
It's just too easy to set timing advance curves to what the engine wants, when it wants it. In my case, the temp goes up, idle drops, ect, I can control a little more advance. You can have a perfect curve pretty simply.
The bottom line is that even a simple tbi will work. It'll work similar to a well tuned carb. Or you can go whole hog. My system consists of a megasquirt ecm, 2011 camaro fuel pump in a vaporworx tank kit, edelbrock victor efi, 2011 camaro fuel injectors, ls truck coil on plug, accufab throttle body, ect,ect. I wanted to run a dead head fuel system at 4 bar to fight vapor lock like the new cars. Many parts were bought used or low mile to keep cost down. I also built the ecm.
Lots of time and money can get wrapped up in efi. But I would not go through the effort without the ability to control timing.
I am waiting for the prototype oil pump drive with integrated sensor on the top. It's been months! Next is an adapter to use a 60-2 trigger wheel. Just another part of the car hobby disease!
Dave
Lee 07-03-2013 01:08 PM
Shop around for the best price you can find on the FAST EZ system, then let me know. I may be able to save you a few bucks.
Lee
lmf01 07-03-2013 05:29 PM
Thanks for all of the info. I have been speaking with several people and researching. It seems the MSD Atomic(dumb name though IMHO) EFI has good reviews. Seems a pretty robust kit. The after purchase support seems strong on their forum.
Car is a weekend cruiser. Looking at this for reliability.
Anyone heard anything or experienced good or bad with them? I have heard of issues with the EZ-EFI.
428GTO70 07-03-2013 06:29 PM
I will be using the Holley Hp EFI TBI system. Its self learning and controls spark, electric fans, etc. Its not installed yet but I should get it going within the next month or so when I get my engine together.
Fishin2Deep4U 07-03-2013 11:43 PM
Lots of good reports on this system. It appears to be easily upgraded as well.
Dave
