-   61-63 Tempest & LeMans TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=427)
-   -   1963 w/ 4cyl. tach (https://forums.maxperformanceinc.com/forums/showthread.php?t=733525)
Transporter 07-29-2013 07:35 AM
1963 w/ 4cyl. tach
On my 63, my in dash tach works, but reads about double the rpm it should, I am guessing that it is a 4 cyl tach? Is there a resister or something I can do wiring wise to get it to read correctly?
Stan
TempestFugit 07-29-2013 11:51 AM
4 cyl 63 Tempest tachs are VERY rare. 8cyl tachs are available repro.
beemergary 07-29-2013 12:55 PM
I only thought the in dash tachs came in the 326 HO and the on dash where the 4 cyl. But I am just talking. Those repop (64 GTO) tachs are the same but are cheap and light needs to be modified but do work.
Transporter 07-29-2013 01:02 PM
Well to be honest, I'm not sure, all I know is the car has a factory "in the dash" tach, and it reads double what it should, either that or I have a 10,000 rpm street machine, lol
I just assumed it was a four cyl car and that is why the tach read double?
Thanks Stan
63Longtop 07-29-2013 01:06 PM
Tach
Stan, the tach came out of a 4 banger stick car!
Transporter 07-29-2013 01:19 PM
Cool Jim, how do I make it read 1/2 of what it does? I'ts a little nerve racking running down the highway at 6000 grand, lol
TempestFugit 07-29-2013 02:08 PM
PM sent
Bill Hanlon 07-29-2013 10:31 PM
Any chance the distributor is from a V8? Don't just look at the cap. Remove the cap and count the number of lobes on the cam inside that opens the points.
TAn2BIRDS 07-29-2013 10:40 PM
Here is a pic of an in dash tach in a 326 car
elefantrider 07-30-2013 03:39 AM
These early factory tachs are a sweet option but so are the clocks in this same space. I have decided to stay with a clock. The factory 90 degree sweep clocks are too difficult to read accurately. I do not have the same problem with my 65 GTO tach but it is a full sweep. FWIW
Transporter 07-30-2013 08:05 AM
Yeah, TA, that is exactly what I have, as far as the dist being a V8 correct, the car now has a 400 in it with an HEI, that is why I was assuming that the tach was reading double.
I'm sure there is some way to correct it.
gtogoat 07-30-2013 08:42 AM
Can you post a pic of the clock? I've never seen one-always a blank in place of...
63Longtop 07-30-2013 09:51 AM
Stan, looks like Dakota Digital make a Universal Signal Interface that will solve the problem. They are $84.95, check it out.
Transporter 07-30-2013 10:15 AM
Great Jim, appreciate it much.
Thanks Stan
TempestFugit 07-30-2013 11:09 AM
1964 Tempest/GTO tach.
Augie Valencia 08-02-2013 04:24 PM
LeMans clock
GTOGOAT, Here is a picture of the clock on my 63 LeMans vert:
gtogoat 08-08-2013 09:35 AM
Thanks Augie for posting-
I knew they were a little different looking but had never seen one...now I know what to look for
elefantrider 08-08-2013 12:05 PM
My car is in storage but I recall it looking rather unique like that also. I like it.
TempestFugit 08-08-2013 12:49 PM
The official name is "Rally Clock"
sdbob 08-08-2013 02:22 PM
Mine had a 326 V8 with tach. someone removed the tach(not me)stole it.I found a4cy tach looked the same to me at the time.
