80T/A Door Wiring Routing? In or out?
Does anyone have a pic of a bare door with the wiring exposed? I have power windows and locks. Does the harness run inside the door with nylon clips or on the inside shell? Just painted the car and forgot where to run the door wiring harness. Thanks chaz069
Which wires? I'll take a picture of my 81 tonight.
The lock actuator wires run inside along the crash support bar bottom held by about 3 clips. |
Wire harness 80 T/A door
There are three small harnesses. Door lock actuator (2 wire), power window motor (2 wire),and the power window switch (5 wires). Thanks for your help. chaz069
4 Attachment(s)
Here you go. Painless Wiring also has some pictures in their instructions for their power window/locks harness. They add 4 relays for the windows. This was one of theirs I added in .
Next time I'll take pics. Thanks for the pics. chaz069
Those help or you need some others? Door panels are still off.
They worked. thanks chaz069
| All times are GMT -4. The time now is 08:08 PM. |
