-   61-66 Big Pontiac TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=428)
-   -   Quarter panel extension seals (https://forums.maxperformanceinc.com/forums/showthread.php?t=746174)
safecracker 01-25-2014 03:10 AM
Hi
Does anyone know where to get the quarter panel extension seals for -66 Bonneville
or what can be used instead if not available?
63gpman 01-25-2014 04:24 PM
I don't believe these are being produced. Mine are good, but I know people have asked about them on some of the cars that I parted out. I thought of using a very small vacuum line cut open or trying to find some edge trim small enough to work like these from mcmaster
http://www.mcmaster.com/#trim-molding/=qepaf6
8LUG 01-25-2014 07:31 PM
Picture of the seal! That would be helpful.
66bonne 01-25-2014 08:08 PM
Black door edge guard {?}
Jim
mike nixon 01-25-2014 09:20 PM
Call P/Y I think the 65 GTO is the same material. It may just be a matter of cutting them longer
8LUG 01-26-2014 01:09 AM
seal
http://www.steelerubber.com/tailligh...pad-70-2166-15
safecracker 01-26-2014 05:31 AM
I don't know if I got it right but on mine there was a piece remaining of a gasket which I believe should be the correct seal. Please correct me if I'm wrong.:confused:
https://dl.dropboxusercontent.com/u/...r/DSC_0349.JPG
Deadhead 01-26-2014 08:16 AM
I thought the 1/4 Ext. stuff was flat.
mike nixon 01-26-2014 03:22 PM
Originally Posted by 8LUG (Post 5117707)
This is what I was thinking of and what my car had on it.
MPKind 01-27-2014 11:28 AM
I've looked for them too with no luck. I can't recall, but I think the headlight bezel seals are very similar. It was suggested to me to use the headlight seal and modify it to fit the rear extension. We'll see...it's too cold to find the parts in the shed to make a comparison.
66bonne 01-27-2014 11:03 PM
That's it. The headlight bezel seats will work on the rear extensions, been there, done that, but forgot to get the T shirt. Mr Kind does it again.
Jim
Ragtop Man 01-28-2014 10:45 AM
Need both F/R seals... can someone point me to the listing for same? Thanks!
MPKind 01-28-2014 12:04 PM
The front bezels seals have been available for a long time from PY or Ames. I have one old rear ext. seal to help modify fronts when they're finally put back on the car...if that day ever comes. HA!
