-   67-81 Firebird & TA Parts FOR SALE (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=451)
-   -   67 68 firebird parts (https://forums.maxperformanceinc.com/forums/showthread.php?t=752338)
woogie0004 04-25-2014 01:20 PM
i am parting out my 68 firebird here is a list of what i have please do not pm me as i do not get on this site a lot email me at [email protected] or call/text me at 810 962 4569 thank you list is current as of 4/25
Subframe NICE 400
Doors 200 each 3 available
Drive shaft 50 each 3 available
Heater control cables 20
Power steering gear box 100
Original inner fenders 100 each driver side available
front valance 50
Drip rails 50 per pair
Window regualator 50 a pair
Door gasket 20 a pair
Tilt steering column 400
Front coils new 40
Center console 200
Cowl cover 25 2 availabel
Th350 crossmember 50
Th350 crossmember modified to fit th400 80
Th400 crossmember 200
Rear glass 50 each 2 available
NIB tubular control arms upper and lower 250
Hood hinges 80
¼ window tracks 50 a set
Complete wiring harness 50
Nova 8.5 non posi rear end 250
NOS pitman arm 30
Washer jug bracket 10
Rear bumper brackets 200
Headlight plated 45 each 2 available
Fender guessets 60 pair
Fender extensions originals 40 each both sides available
Taillights 60 dollars
400 hood scoops inserts originals 100 per pair
Shifter with nob and plate 150
Shifter 100
Parking brake pedal 25
Brake pedal 50
Gauges rally 67 120 mph speedo with housing 250
Gauges rally 160 speedo with hosuing 250
Heater controls 125
Dash bezel around radio ash tray 30 2 available
Glove box door 20
A pillars 25/pair
Visors 25/pr
Arm rest 25/pr
Rear view mirror 24/pr
Headlight switch 15 2 available
Steering column braces 25
Lighter 10
Washer/wiper switch 15
Speaker bracket 15
Inner fender brackets 30/pr
Wiper arms 30
Horns 20 each 4 available
Fuel door 40
Washer jug 10
Fuel neck 20
Fuel neck cover 15
Gas pedal with cable 25
Wiper motor with trans and rebuild kit 100
Floor pan under rear seat 30 each both sides available
Grill inserts 20 each 3 available
Rubber that goes in front bumber ends 100 per pair
Seats 350 a set
Heater vents 100
Front turn signal leses 60
Headlights and buclets 60 for 4
Hood latch 125
Leaf springs 100
Motor mounts 50
Repop rubber motor mounts 30/pr
Turn signal metal housing 100/pr
Wire cover under sill plate 80 a set
Gas tank straps 20
Rear arm rest 150/pr 2 available
Sail panels 40/pr
Duct work 30 each 2 available
Ash tray 40 2 available
Heater core box NICE 100
Seat belts 30 each 12 available
Horn button 100
Column cover 25
Front window trim 125
Rear window trim 125
Ac filler panel only one side so far 40
Decklid 100
robscar 04-25-2014 05:18 PM
I sent you a pm about the 67 rally gauges.
woogie0004 04-29-2014 10:43 AM
updated list please do not pm email call or text
Subframe NICE 400
Drive shaft 50 each 2 available
front valance 50
Front coils new 40
Center console 200
Cowl cover 25
Shifter 100
Heater controls 125
A pillars 25/pair
Lighter 10
Speaker bracket 15
Wiper arms 30
Washer jug 10
Fuel neck 20
Fuel neck cover 15
Seats 350 a set
Heater vents 100
Leaf springs 100
Gas tank straps 20
Sail panels 40/pr
Horn button 100
Column cover 25
Donovan 05-16-2014 01:45 PM
Received the box and gauges. Looks great, packed well. Better than described. Thanks and bump up
robscar 05-19-2014 02:07 PM
The 67 rally gauges and th350 crossmember both arrived last Fri. The gauges look very nice. Better that the pic's showed.
Thanks,
Rob
Jc68fbody 05-26-2014 12:51 PM
Any pics of hood latch??
[email protected] 08-07-2014 08:11 PM
do you have the 67 firebird door glass track assembly ?
ls3bird 06-09-2015 02:56 PM
Console still available?
KennyH 11-15-2016 11:52 AM
68 firebird
I'm interested in your th. 400 cross member and your drive shaft if it's for a th. 400. Thanks, Kenny H
Hotrodjohn71 02-15-2022 12:59 AM
Hi. Do you have the interior rear view mirror?
grandam1979 02-26-2022 07:54 PM
He has not been on the site since 2019
