-   -   Trans Am Drop Link Bushings (https://forums.maxperformanceinc.com/forums/showthread.php?t=753485)
Firebird 2 05-13-2014 01:43 PM
Where does one purchase the 7/8 bushings that go on the rear sway bar from the drop links??
70RAlll 05-13-2014 06:25 PM
The best material that is closest to the original is a section of heater hose with a .875 id. that is the correct thickness and just about the same material. Have a set of NOS GM bushings and that is what they basically are(have a beveled ends)thickness and material is heater hose.
murphc4 05-14-2014 08:46 AM
I used the info from this post to get everything I needed.
http://forums.maxperformanceinc.com/...d.php?t=621038
