-   -   would you use main cap bolts of unknown origin? (https://forums.maxperformanceinc.com/forums/showthread.php?t=757267)
mike76 07-12-2014 05:45 PM
Just wondering
track73 07-13-2014 11:07 AM
Here's what I would do. After checking for cracks, install them and see how good or bad they fit. If they are deemed acceptable get the block line bored.
PunchT37 07-13-2014 11:39 AM
Shouldn`t need a line bore for bolts.
PunchT37 07-13-2014 11:43 AM
I would have a good look at em.. Check the head to see if fools mistreated them, check the thread condition, and, if you can find the specs, check the bolt length to see if they`re not stretched beyond their yield.
Course, new bolts ain`t high $ either.
gtofreek 07-13-2014 12:26 PM
Were they actually main cap bolts, or just some bolts you want to use for main caps? I would not use a bolt that was not designed for main caps.
mike76 07-13-2014 01:21 PM
These are a factory set of 4 bolt main cap bolts with the shoulder under the head. I bought these from a PY member some time ago . In appearance they look good but, with anything so old I'm wondering ( short of magging) if they would suit a 525-550 hp street/strip engine w/o issues. The block was lined honed years ago using the original caps and bolts .Those bolts were lost and these are a replacement. Thanks, Mike
b-man 07-13-2014 01:29 PM
Factory hardware is of high quality.
I doubt they've been torqued down more than a couple of times at the most during their life.
I'd use 'em in a heartbeat, just like I'd use the original main bolts on my '64 421 HO rather than replace them with new aftermarket bolts.
