-   70-72 GTO Tempest & LeMans TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=436)
-   -   Axle ratio question (https://forums.maxperformanceinc.com/forums/showthread.php?t=758036)
C130 07-23-2014 12:00 PM
Axle ratio question
Hello all I recently purchased a 1970 gto with the original M21 trans, the previous owner said the axle ratio was 3:55 from what I have been reading the car would have been equipped with a 3:90 rear end. I know its not a 4:33 from driving it, what are the chances that it is a 3:55 ratio, the axle code is no longer visible on the tube after 40+ years of rust and paint. Thanks for the help.
Diego 07-23-2014 12:11 PM
I think PHS will answer this but, yes, M21 normally meant 3.90 or lower.
mmarx 07-23-2014 01:54 PM
If it was a 455 car, i think 3.31 would be the standard gear and 3.55 optional. Does it have a 12 bolt rear?
Baron Von Zeppelin 07-23-2014 02:43 PM
Jack up the rear and secure it.
Rotate a valve stem one 360* rotation.
Count the number of rotations the driveshaft yoke makes.
On a posi - it will be the full count.
Non-Posi - double the count. (1.75 turns would = 3.50)
Matt Meaney 07-23-2014 06:30 PM
factory A/C car? no 3.90's with A/C.
how do you know it's a M21 and not a M20?
C130 07-23-2014 06:34 PM
The car has a 400 CI. engine, the window sticker has G80 safe- t- track differential- HD 361, underneath that there is G92 axle-special order 362 but I haven't found what the codes translate to.
C130 07-23-2014 06:39 PM
No air, the trans is coded to a M21 which is on the window sticker and the serial numbered is stamped on the trans which matches the car.
Baron Von Zeppelin 07-23-2014 10:36 PM
On a WT or WS car , those codes can apply to 3.90 or 4.33
The factory build sheet would be the only way to know which of those it was built with.
You would probably recognize a 3.90 while driving it.
Previous owner was probably right about a 3.55 being under it now.
1969GTO 07-23-2014 11:43 PM
the car is 44 yrs old, lots can happen in 44yrs. jack it up,pull the diff cover count and devide the teeth, you will then know for sure...no guessing.
MescaBug 07-24-2014 10:56 AM
There you go. No guessing.
C130 07-24-2014 03:19 PM
Thanks for everyone's input, I did the tire rotation test and it is indeed a 3:90 gear ratio.
Diego 07-25-2014 02:02 AM
What motor do you have?
C130 07-25-2014 06:25 AM
The motor is a 400, WT coded.
Diego 07-25-2014 04:38 PM
That motor is rather rare with the M21.
Matt Meaney 07-25-2014 09:20 PM
that's great!
a 400, m21, 3.90 is a great combo for spirited driving. enjoy.
how about some pics to share?
slowgto 07-26-2014 05:11 AM
Another thing you could check, for the HD rear, is the casting number on the back of the rear, which should be 9799202. There will also be an "N" cast into the top front.
C130 07-26-2014 09:24 AM
The casting number on the axle looks like 9799202; the number's are well worm do to corrosion over the years. I'll try to get some pics later this weekend, I'll have to read up on uploading pics the to the web sight.
C130 07-26-2014 01:41 PM
5 Attachment(s)
Here's a few pics.
trishieldchief 07-26-2014 04:26 PM
Smart way to order a standard GTO.
Poor boy way of getting max performance on the cheap.
Matt Meaney 07-26-2014 05:48 PM
very nice!
