-   77-81 Firebird & Trans Am TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=441)
-   -   Battery Hold Down (https://forums.maxperformanceinc.com/forums/showthread.php?t=759285)
Bentwheelbob 08-12-2014 05:41 PM
Battery Hold Down
What was used on the battery hold down bolt to secure the top clamp? Was it a washer with a wing nut, a washer with a separate hex nut, or a flanged hex nut with no washer?
78 TA KID 08-13-2014 06:33 AM
Mine T/A has the a flange hex nut with no washer
77 TRASHCAN 08-16-2014 05:47 PM
same here
Bentwheelbob 08-16-2014 09:17 PM
OK, I am officially looking for a 5/16" flanged hex nut for the battery hold down. I have checked all the parts suppliers and cannot find one. I found a couple at Home Depot and Tractor Supply, but the flange is way to small. Does any one have an original in their junk pile or on a parts car?
gilg 08-21-2014 10:30 AM
https://www.amkproducts.com/
GM 489090 NUT
AMK B-12837 NUT 5/16-18 1/2 AF .75 OD .35 OAHF S2 (4)
GM 3823275 BATTERY HOLDOWN
AMK B-11673 J-BOLT (LQO) 5/16-18 X 7 7/8, ZC. 1 pk
Bentwheelbob 08-21-2014 11:07 PM
That's it. Thank you.
burd 09-04-2014 10:04 PM
Dang I could have brought you one at the Natz, I have a box of them. I put a plastic washer on there too to prevent the nut from digging into,the rubberized coating.
Bentwheelbob 09-05-2014 12:03 AM
Thanks Burd, it's not too late. I've been busy trying to get the heads, intake and cam lined up with SDPerformance and haven't ordered a nut from AMK yet. Add one to my shopping list and send it with the rest of the stuff once you figure out the price. Thanks again.
Judge273 09-05-2014 08:44 AM
What's the part number on that plastic washer?
RamAir 09-05-2014 10:01 AM
Do you have any J hold down bolts? I'm using a spare tire aftermarket one that's too long
