Master cylinder question
Can I use a disc/drum master cylinder on a drum/ drum car
Don't think so!
In all the years I worked as a auto parts counter man I always sold one for each, never one part number for both" |
thanks steve i know they are two seperate parts but im curious if it will work
The drum type master has a check valve to keep some fluid pressure in the system when the brakes are NOT engaged. If you dont have this the brakes will be spongy or won't work on the first push of the pedal.
Called a residual valve.
...and GM quit using residual valves in 1970. See "Note" under figure 2-5:
http://hbassociates.us/Delco_Brake_Manual_03.jpg |
I always heard that disc brakes require more fluid (volume) to make them move. If you use a disc m/c on drums, the drums will over-extend (drums don't need as much volume). If you use a drum m/c on discs, the disc won't clamp all the way. You can look up specs on disc v. drum m/c's and see the bore in the disc m/c's are larger, which means as the piston moves down the bore, more brake fluid is displaced in the disc m/c than in the drum m/c.
A disc master cylinder needs a larger reservoir of fluid due to the fluid "permanently" transferred from the master cylinder to the disc caliper as the pads wear. |
| All times are GMT -4. The time now is 05:49 AM. |
