-   67-79 Big Pontiac TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=431)
-   -   Need help with trans cooler lines (https://forums.maxperformanceinc.com/forums/showthread.php?t=761068)
scld1354 09-12-2014 10:16 AM
Long winded, sorry......I've swapped a 200-4r into a 67 GP that originally had a TH400. The install went about as expected; we had the trans in and out about half a dozen times, and ended up braking the trans oil pump. In an effort to get the car running, I made some temporary cooler lines. Now I want to go back and install permanent lines.
The original lines from the TH400 were cut up, and the only thing I could salvage were about 1' of line and the fittings to the radiator. This line is 3/8, and based on the fitting on the trans, the fittings have a 1/2-20 thread. Most of what I can find says that most applications came with 5/16 line, but that 65-68 big cars came with 3/8 cooler lines.
I can get steel brake lines from the parts store, but in order to get the 1/2-20 fitting, the lines have to be 5/16. Does anyone know where I can get 3/8 line with 1/2-20 fittings?
If not, will 5/16 line move enough fluid to keep the 200-4r cool?
Thanks in advance!
jdh421 09-12-2014 11:20 AM
you should be able to get the correct nuts from a parts store or Fastenal. you might also try a transmission shop for fittings. I would use the 3/8 line just for capacity. my 2cents
