-   93-02 Suspension Tech (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=541)
-   -   Tech tip on the 93-02 (& 82-92) F-Body lower control arms. (https://forums.maxperformanceinc.com/forums/showthread.php?t=764727)
SteveGB21 11-15-2014 11:59 AM
I found out today that if you buy the inserts for the '64-'72 GM A-Body Lower Rear Control Arms, that they also will fit the '82-'02 F-Body. That is what I will do instead of buying a set of control arms. If anything helps with saving money (only got the polyurethane bushings) then that will work for me. Car is a V6, and I don't plan on using it as a drag race car or trying to maneuver as fast as I can. Just a daily driver.
Now, if I only can obtain an insert for the panhard bar.
