-   -   1998 Trans Am with a Butler Performance 462 Pontiac Motor (https://forums.maxperformanceinc.com/forums/showthread.php?t=767179)
machota154 01-01-2015 12:12 PM
2 Attachment(s)
This is my 1998 Trans Am that I am installing a 462 Pontiac motor along with a 4L80E.
machota154 01-01-2015 12:20 PM
4 Attachment(s)
I used a BMR turbo k member that utilized pedestal mounts. I used a combination of their mount and mine to make it work.
machota154 01-01-2015 12:35 PM
5 Attachment(s)
Had to lower the steering rack about an inch to clear the oil pan. Guess I'm going to have to get a bump steer kit to straighten the rack geometry out.
72projectbird 01-01-2015 07:47 PM
This is pretty cool! Should really move when its done!
machota154 01-01-2015 08:12 PM
462
Thank you, I can't wait to get it done.
machota154 01-03-2015 11:39 PM
Springs
3 Attachment(s)
I installed my QA1 shocks and springs. UMI upper and lower control arms.
Txbobcat 01-04-2015 10:37 AM
That ought to be a mover when you get it done.
JSPONT 01-04-2015 11:52 AM
Now that's what GM should have kept doing! Real cool, go pro the first beating please!LOL
machota154 02-01-2015 10:04 PM
2 Attachment(s)
I finally made my steering shaft. Since I had to lower the steering rack, the shaft would not reach the rack. So I made my own. It is made from the ends from the 4th gen and the telescopic part from an Astro van.
JSPONT 02-01-2015 10:35 PM
cool, yeah the little things are time consuming.
grivera 02-01-2015 10:50 PM
Nice work! Great to see old muscle in a newer ride!
72blackbird 02-01-2015 11:34 PM
AWESOME! Payback is a bi-atch, LS fans!
2002Z4CSS 02-02-2015 09:41 AM
Are you going to be able to run an air cleaner on that engine?:)
machota154 02-02-2015 08:59 PM
Not much of one !!!!
I am going to use a low profile air plenum, then into air filters.
Hopefully !!!!
fiedlerh 02-02-2015 11:20 PM
How is distributor access? Can you get the cap off?
The rule of thumb for suspension design is the steering tie rods should run parallel to the lower control arm throughout the suspension's travel to minimize bump steer.
machota154 02-02-2015 11:46 PM
Distributor cap can be removed with no real problem. There is more room there than you would think.
As far as the steering rack goes, I lowered the rack about 1 inch. Hopefully the adjustable bump steer kit will help.
HWYSTR455 02-03-2015 09:29 AM
Subscribing...
I was thinking about doing this type of a swap, the V6 bodies are plentiful, affordable, and still in pretty good condition.
What kind of rear are you planning to use?
Any chassis stiffening/bracing?
Please keep up with posting progress and any issues, etc you may have. Many are interested.
prostreet64 02-03-2015 10:25 AM
Ditto what HWYSTR455 said, many of us are interested in this project.
quicksilver97ta 02-09-2015 04:32 PM
^^^ This!!! LOL!!!! :p
ChiefPonch 05-17-2015 06:22 PM
Awesome! You just saved me from posting a new thread asking about a Pontiac engine in a late model. I've been pondering it for quite some time. Whenever I finally get started on this project, I will have a ton of questions. Mine will be a well-built 400 street car (hoping to clear 500 horse) mated to a T-56. I hope you don't mind me bothering you and sending a couple of messages. I'll try to keep it to a minimum. Your thread and pics have answered many of my questions already & I am subscribed. Thanks for your help!
