-   64-65 GTO Tempest & LeMans TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=429)
-   -   1965 gto clutch spring and linkage picture (https://forums.maxperformanceinc.com/forums/showthread.php?t=767338)
JIMMYM 01-03-2015 10:21 PM
I know i have seen a picture on this forum of a clutch linkage and spring installed on a car. will someone tell me how to find it. or has anyone got a picture? thanks
bill ryder 01-03-2015 11:56 PM
http://forums.maxperformanceinc.com/...=clutch+spring
Try this thread. No pictures, but a very good explanation. "Bill"!
3 Deuce 64 01-05-2015 09:52 AM
65 Z Bar to Fork spring
On the original exhaust pipe flanges there is a hole the spring goes in then back to the hole in the clutch fork . Hope this picture helps .
bill ryder 01-05-2015 11:35 AM
GREAT PIC. I was thinking setup was still the same as 64. "Bill"!
dld 01-05-2015 06:10 PM
2 Attachment(s)
here is how mine looks on my 65.
bill ryder 01-05-2015 06:15 PM
Looks the same as mine on a 64. "Bill"! Mid year? You 65ers jump in!
dld 01-05-2015 06:20 PM
After seeing post from 3 deuce 64 I thought I should post this. I'm not sure whats correct.
bill ryder 01-05-2015 06:32 PM
I just had to look. My 65 MPC shows 64-66 tempest the same with the return spring around the bearing fork, not thru he hole. I also saw diagrams of big cars using the hole in the fork. "Bill"!
3 Deuce 64 01-05-2015 07:16 PM
Interesting I just checked my 65 service manual on the 6 cylinder it show from hole to hole but on the V8 as dId shows . well mine must be wrong and so is my 64 . I just had the tranny out of that and I know it's the same way and has been ever since I've owned it almost 38 years now . Sorry about the misinformation . I'm rebuilding the WS over the winter hopefully and will correct it when I put it back together .
JIMMYM 01-05-2015 07:57 PM
Thanks to everyone.
Thanks to everyone for the pictures and info. If not for this forum i would have never got as far as i have. I hope to finished by april. Randy F
propuckstopper 01-05-2015 08:20 PM
Same
My '65 looks exactly the same as dld's.
dld 01-05-2015 08:21 PM
I'm not sure your wrong. My car had that long spring on it when I got the car . But I did not pay much attention to it when I tore it down. When putting it back together the only spring I had with parts pile was that long ( hole to hole type) I could not get it on what looked to be correct. The car has the Gardner Exhaust on it and has the hole in flange but still did not work out . I got the type that I show out of the Ames or PY catalogue. that was described as correct???
dld 01-05-2015 08:24 PM
Your correct in comment on this forum. Its Excellent !!!
Tom Vaught 01-05-2015 09:26 PM
X2 on the hole in the exhaust flange to secure the front of the spring (on my 64).
Tom V.
