Pitman arm for 1969 Firebird
I thought these were fairly common, but apparently not!
Please get it touch if you have one for sale. 1969 Firebird. PM me or send an email to john.creuziger@cruzeware.com I'm changing over from manual to power steering and need the pitman arm. Thanks, John |
Try these guys. A lot of times if they don't have it they can get it.
http://www.frankspontiacparts.com/en...ngineparts.htm |
Checked with Frank's....struck out.
Gotta be one out there! |
Try this:
Performance Years Part # RFU-213B You may have to switch out your Center Link too. |
1969-74 Nova is the same????
Thanks! |
I'll check the Nova compatibility.... |
I have this pitman arm, sent you an e-mail.
Well, I'm still looking for this elusive pitman arm!
461bird offered a swap for my manual setup but I'm keeping that. Anyone out there with one to sell? Same contact info...pm me or shoot me an email at john.creuziger@cruzeware.com Thanks, John |
Have you looked into a '69 Camaro pitman arm:
http://www.summitracing.com/search/y...1%2B4294947064 Not sure it's same for Firebird.... if it's different (between 'bird & camaro), then you could consider swapping over the entire steering linkage to Camaro to insure compatible parts. Probably costs less than 150 bucks for a complete, new Camaro setup. I thought about doing this 10 yrs ago for my '69 Firebird... I needed an idler arm and NOBODY offered a new one. Some time later, a company called "Rare Parts" offered it for $150. I was shocked... almost swapped everything to Camaro since it was cheaper than the single firebird idler arm... but then bit the bullet and paid for the "Rare" part. I kick myself for not swapping to Camaro parts back then... especially with the thought of needing another Firebird piece (since I still drive the car a lot, including Hot Rod Power Tour). Good Luck! |
What would I need beyond the pitman arm? New center link, I'm sure. Anything else? Thanks! |
Is the 69 the same as the 68 pitman arm ?
If you swap to 68 camaro or firebird
youll need to change pitman arm -idler arm center link and inner and outer tie rods 68 birds and camaros used the same center link not sure 100% on the other stuff though that 69 pitman is a tuff one to find for sure |
pitman arm
I have a 67 gearbox with pitman arm. Will that work. Also have the rest of the linkage if needed.
Hi
are you looking for the 69 only curved Firebird pitman arm
part number 7806616 ?? for power steering I have a sweet one if so Scott |
Why are you changing the pitman arm?? When i went from std. steering to power steering all I changed was the steering box & put the arm on that was on the std box & it worked just fine , no problems at all. Ran the hoses & worked the way it should have . I didn't change the pitman arm, this was on a 68 conv. bird. >
Original'60's and '70's GM PS pitman arms had a larger splined hole than same application manual steering pitman arm, that is why JCruz is looking for a '69 Bird PS pitman arm #7806617
When did you have your Firebird, Rex? |
pitman 7806616
3 Attachment(s)
pictures of a spare, possible 69, Firebird power steering pitman arm..
taken yesterday 9-23-15 ......... it was in a box with a complete 69 Bird Hurst shifter and clutch/brake pedals ..and 69 rear bumper brackets,\ that just came out of a ,take everything in the shed, purchase...last week Scott |
