-   -   Console wiring harness (https://forums.maxperformanceinc.com/forums/showthread.php?t=777244)
nogto 07-19-2015 05:57 PM
I have a new MH wiring harness for the console shift indicator. The original wiring harness was removed from my 69 Lemans auto console before I had it. The new harness is gray wire. What color wire am I looking for from the dash harness?
2002Z4CSS 07-20-2015 08:12 AM
Another gray wire that is has power on it when the headlights or parking lights are on. :)
nogto 07-20-2015 10:17 AM
Thanks but i found a more specific answer searching under clocks. Turns out that the clock light and the console indicator light connectors are identical and fit together. Both connectors are clear plastic series type with a gray wire. Not to be confused with the clock power which is an orange wire with a blue connector.
MD79TA 07-20-2015 09:35 PM
Something about your answer just seems condescending . If you know the answer why ask... Sorry just had to get that off my chest Doug
nogto 07-21-2015 08:59 AM
I looked for a long time under console wiring but no one seemed to know. It is not specified in the wiring diagram either. I continued to look in electrical after I posted and found the answer so I thought I would share it. Just a timing thing, sorry if it seemed condescending. . I appreciate py forums because the answer is always there somewhere
