-   Electrical Tech (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=424)
-   -   Wipers were working now just stopped??? (https://forums.maxperformanceinc.com/forums/showthread.php?t=777827)
Check6 08-02-2015 05:16 AM
Have a 66 GTO. Turned on the wipers and pump and both worked fine. Turned them on again and now I can't get anything to work. Changed the fuse and I have power to the switch and all the connectors to the wiper motor. I tried a different switch same results. When I press the washer button I get a click in the pump housing. Any ideas??
Thanks,
Fred
Old Goat 67 08-02-2015 05:54 AM
Bad ground on motor housing.
