Checking windshield wiper/washer motor on a 66 GTO
Anybody know how to trouble shoot a windshield wiper motor on a 66 GTO?? Can you run jumper wires from the battery and where do they go. This has 2 speed wipers and windshield washer. Just want to know if the wiper motor is good.
Thanks, Fred |
Fred, I can't help out on testing it but.....
If you do need a replacement, go to NAPA. They will have them, or can get them, and they'll work right out of the box. Stay away from the likes of Auto Zone. I went thru 4 of theirs that were no good. Napa's worked like a charm. |
GT182,
Thanks for the heads up. Fred |
You're welcome Fred, and good luck. I hope someone can tell you how to test it and save you some money.
BENCH TEST
This may be of help;
http://www.chevelles.com/forums/showthread.php?t=711666 |
Hi Jeff,
Thanks, that's exactly what I need. I'll let you know what happens. Thanks, Fred |
Is it the original date coded motor?
All I know is that the ones from NAPA are painted as the originals were, and are far less expensive than anywhere else you can get them from. ;) Plus they work the first time right out of the box. :D |
Where would be the date code? What numbers would I be looking for?
Date code would be stamped in yellow ink on the side facing the engine compartment. It should be a Julian date such as 343 65 or there is a foil decal on the side nearest the fender that would also have a Julian date for the build. For rebuilding www.WiperWorks.us
Cool. Thanks for the link SR-71. :thumbup:
Your welcome, glad I could help.
| All times are GMT -4. The time now is 11:41 PM. |
