-   YOUR BEST PONTIAC STORIES (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=471)
-   -   My 67 gto (https://forums.maxperformanceinc.com/forums/showthread.php?t=784806)
MUSLCAH 01-09-2016 01:48 PM
My 67 gto
http://images.tapatalk-cdn.com/16/01...52a92c10b7.jpg
bendutro 01-09-2016 02:02 PM
Good looking beast, original or restored? Is your rear antenna fixed or powered?
My '67 is mounted on the front fender, why did GM move it?
MUSLCAH 01-09-2016 02:12 PM
Just got it this past Sept..someone put a so-so paint job on it... No resto....it's a great driver with matching motor ,trans,rear end,PHS ..power window,ps PB, factory AC,door edge guards..and yes power rear antenna...column shift with buckets..parchment int. I call it my 20 footer...orig solid floors and trunk. But not a Calif. rust free car...1/4s had some work...but pretty solid if you ask me....and its on a convertible frame too. I guess you could order the antenna any where you wanted back then.
Greg Reid 01-09-2016 02:47 PM
Great looking car!
Goatracer1 02-04-2016 12:11 AM
My 1967 has the power ant. there also. I don't think it would fit in the front.
